E250 Gauges Installed, now no rear AC/Heat fan
jayro88
Auburn IN
Hi all,
Got my electric fuel pump and trans/EGT/Water temp gauges installed. Trans is staying in the 150-160* range, EGT 550*-700* and coolant 200-206*. Here is a pic. Temps in the pic aren't correct. Vans wasn't running and was turned off about 5-10 min prior. I think my coolant temp is reading a little high due to my choice of sensor location. I used a coolant port at the back on the drivers side head near the exhaust manifolds.
This is the port I used for the coolant temp except I used the one on the drivers side:
Here is the c6 trans temp sensor location:
So the seem to be working well, but now my rear AC/Heat blower isn't responding at all. Only thing I can think is that maybe the ground under the dash isn't making a good enough connection after I attached the gauge ground to it, or a fuse. Thing is the front blower works perfect and according to my owners manual it is all one fuse. Any ideas?
bleachasaurus
Staff online
