FORDF250HDXLT
Just to add some more confusion to this mix, Rockauto lists 2.5", and 3" for my 93 F250 (I'm assuming that is Semi-float vs Full-float); If you look into the 93 F350 it lists 3" and 3.5" for both DRW and SRW applications.
So certain single wheel trucks may have bigger shoes than certain duallies?
yeah,the light duty f250's take the 2.5" shoes.
as for f350,but i always forget this;
did the cab and chassis (which happen to be duallies without a dually rear,but a narrower frame and springs instead) use the 3" shoes? this might explain that.
i hope im not wrong because now i'll just be passing on my own confusion if so lol.
quick search shows i didn't know for sure back in 2013 either.only difference is,then i guessed they did get the 3.5" pickup drw shoe lol.
http://www.oilburners.net/forums/showthread.php?64925-Rear-brake-shoe-size
