The pickup dually axle is physically longer from wheel mounting surface, to wheel mounting surface than a SWR or CnC Axle is. They are a different casting, axle shafts, etc........
However, a CnC Dually axle is the same width as a SWR Pickup axle, but the spring perches are closer to the diff, because the frame width on a CnC is an "industry standard width" of I believe 36" between frame rails and the rails are of a straight/flat design, and a pickup frame is 39' wide and the frame rails are not as straight/flat as a CnC....
