6.9poweredscout
Bleeds IH red...
Yea I'm thinking ill look for about that too, its mainly going to be a tow rig and truck puller. Definately going to look for detroit lockers for it. I'm hoping for a 5 speed trans too. Doesn't matter if its OD or not.
The guy uses the travelette everyday and has gone on several 800 mile trips. he says he would trust it, he greased the bearings and relaced all the fluids. I think ill figure out my route and post a roadtrip thread to get some contacts and help along the way incase I have any snags.
I'm pretty sure its a complete running engine. I have to look into it, all the local ones and ones on ebay are on the $2200+ range.
-Jon
-Jon
Jon, I'm looking at 3.55 gearing for the axles. I'll have to see what's available as far as axles for the carrier (will change with 3.55) with that gearing. And, what carrier I can get in a locker/LS. But, with the torque of the DT466 and the low 1-3 of the Eaton Fuller, I can easily get away with taller gears if needed.
If the Travelette is in good shape, I'd be temped to just fly there and drive back. What a hoot that'd be.
$1500 is a bit higher than I paid. I pick mine up for less than $900 and Darrin Tosh picked it up for me in MI and I met him in Cincinnati to help him buy a truck and swapped the DT from his truck to mine then. Make sure you get everything with the DT from the starter all the way to the motor mounts. That kind of stuff will nickle and dime you to death.
Heath
