miked
Hello
I am converting from e4od to zf5 in my 1994 f250 idit
short story.
I have a 1990 cross member from a 1990 zf5 which would have been perfect but is rusted too badly to use.
Found an L shaped cross member in my parts stash which matched the frame bolt face to tranny mount bolt face off set that matches the height offset on the 1990 cross member.
One side bolts to the outside of the frame.
The zf5 cross member has a greater off set between the 2 faces (frame to tranny mount) than the e40d cross member,
The transmission is in, with the L shaped member clamped in place ready to drill matching boltholes in the frame and the drive shaft with hanger bearing is also installed, which when I looked at it made me decide to check my drive angles.
What I found
The face of the transfer case yoke, and the face of the rear end yoke, are less than 1/2 degree out to each other.
So centre line angle of the engine-transmission and centre line of the axle yoke are on the same axis.
I am asuming that the transfer case yoke is in line with the trany center line.
The drive shaft spline is 5 degrees out to the yoke faces and needs to move downward to correct this.
Using trig, I calculated that I need a 2.45 inch spacer under the hanger bearing to correct the 5 degrees.
I will make this spacer and recheck the angles.
My concern is why I am having to do this ???
Am I missing something?
any insight would be appercated.
Thanks
short story.
What I found
Thanks
