Does delphi lift pump get you guys approval?
larson
Springtown,texas
I have read on here not to buy the airtex lift pump.
What about the Delphi lift pump? Any one have any problems with it?
bobs_idi
United States
the delphi is just a repackaged airtex. or used to be at least
Save up 100 more bucks and get a good e-pump.
Rock Auto used to have a good deal on Facet pumps.
larson
Springtown,texas
whoops
meant Pegasus, not Rock Auto.
One day yes I will install an e fuel pump but at the moment its not going to happen. I went ahead and got the Delphi due to mine leaking. I guess ill find out if it's worth a s**t. If its like your saying then they are all s**t cause you could put any of them in a bag and call it what ever you want and visually not tell a difference between them if there was no name on the side.
ironworker40
NYC Ironworker
nj
I have a delphi and when i turned up the fuel screw or change filter it puts out enough fuel that it doesnt even stall. With the old pump it wouls start then stall. Then a lot of cranking. 4000 miles so far
