Do the Fe engines use an SAE 3 bellhousing
jspaul
Pakistan
Thinking about putting a 12 valve or a 4bt in my 75 and I want to know if I can pull the 390 out and bolt a Cummins up to the c6
You will need an adapter plate to mate the Cummins to the C6... Not a direct bolt in.... I had go 4BT over 12V... fits better in my 75 and still has plenty of torque... You also need ....custom motor mounts, bigger radiator, and exhaust work...
What's the goal - mpg or just want diesel power?
u2slow
bilge rat
Coastal BC
4BTs easily cost double around here, and dont come with the handy pickup-truck jewelry.
If saving space is critical, no intercooler helps. I'm really happy with non-intercooled (5spd) dodge actually, as a driver/commuter.
