Cincinnati Guy
Im looking at my Jeffs bronco junkyard book and it has a good detail cut away of the Dana 60 front axle. My axle is leaking gear oil around the steering knuckle area, which makes me think the seals are bad? What seal would it be? The seal right behind the inner Wheel bearing? How is this changed? Do I have to remove anything else besides the Wheel hub, wheel bearings?
Also my flange wiggles around a bit, maybe its not torqued enough, whats the spec? That or the outer pinion bearing is bad?
