Oh boy....I'll do my best to not miss anything.
jack the truck up, axle stands holding it. Remove the wheel. Remove the brake caliper and make sure to hang it by wire from the frame. DO NOT LET IT HANG BY THE HOSE!!! (tap the pins out that hold the caliper on, and don't destroy the ends by hammerin on them).
Now, remove the locking hub (6 allen bolts). The locking hub end cap will now come out...wiggle it if needed.
Remove the big metal sprial lock (it's into a groove on the hub, it holds the "fuse" into the hub). Now, remove the screw that is holding the "fuse" in. It will now fall right out with a spring behind it. Finally, pull the snap ring off the axle shafts (not sure if there is ont or not, might be, might not be) and you can thread two of the allen head bolts into the hub and pull it.
Now, you will need a specific socket to pull the wheel bearings. Remove the outer nut, then the locking ring, then use teh socket again to pull the inner nut off. Inspect them carefully for ANY signs of wear. Any blueish tinges, pits or de chroming, replace them.
Now, pull hard outwards by using the brake rotor as a handle...the hub will come off. Try not to drop your outer bearing in the dirt.
You will find 5 or 6 nuts holding the spindle on. Remove those nuts, and go find a piece of hardwood.....you are going to need it.
Put the two spindle nuts on to cover the threads at the end of the spindle from accidental impact. Place the hardwood over the spindle and hit the piece of wood HARD up, down, side to side....it will make the spindle come loose. Keep this action up until the spindle comes out. It might seem hopeless, but it WILL move!!
With the spindle out of the way, you can pull the axle shafts. I can not remember if the passenger side shaft somes out of the pumpkin, or separates at the middle joint via a slip joint, but I do know you can get both shafts out of the way without removing the pumpkin.
Assembly is just teh reverse, but use LOTS of antiseize on the spindle to knuckle seam, as well on the ball joints when they go in the knuckle. This will prevent bleeding knuckles next time. Trust me, I know!
Be VERY careful installing the ale shaft into the pumplin....or you will be cursing fords for a LONG time after you fix the seal.
If you have any problems, we're all watching and can answer. Just post, or PM someone should the ***** matter hit the air recircilation device.
