Dana 50 & 60 Parts Interchange
jhenegh
Truck Still Earns its Keep
Deerfield, WI
In relation to my earlier post about cost to rebuild a 50 or 60; which parts are the same between the two? I'm not talking ring & pinion, but balljoints, U-joints, bearings, brakes etc. The somewhat "normal" outer wear items.
Thanks!
kpj
Finland
I just did the swap to my '93 D50 from '90 Kingpin D60, so i don't know about ball joints. But here's anyway
Don't Interchange
- Knuckles
- Spindle (Flange to knuckle is too short, otherwise the same)
- Spindle seals
- U-joints
- Outer axle stub, because of u-joint
- Brake dust shield, maybe with little modifications
Does interchange
- Brakes (rotor, caliber, pads etc.)
- Hub (seals, bearings etc.)
- Spindle bearings
- Bearing tightening nuts
Someone else might know the list if your swapping a ball joint style D60.
JunkCowboy
