TNBrett
As the title says I have a 3cyl Daihatsu engine for sale. Its a model DM950DTH. It was Marketed by Briggs & Stratton as a Vanguard 3/LC. It is turbocharged and rated for 35 hp @ 3600 rpm. This was a running engine that I pulled out of a piece of equipment when I repowered it with a Propane engine. It was repowered because most of our customers would no longer allow us to run it indoors. EVERYTHING is included that you would need to install this engine on whatever you can think of.
B&S control panel w/ complete harness (fully labeled).
Throttle control cable
Fuel Gauge and Electronic Tach
Radiator w/ shroud, mounting brackets, hoses, and overflow bottle.
Fuel filter assembly, electric lift pump, and Donaldson Air filter housing.
3 sets of exhaust, all 3 were Catalytic converters. One is fairly new, and one was gutted.
Solid motor mounts, fan, alternator.
8 gallon fuel tank (fuel level sender is inop).
Output shaft is 1-7/16" x 2-13/16"
Take a look at the pictures and video, and let me know if you have any questions. I'm asking $2000 or make me an offer. Its at my shop in Nashville. I have a forklift to load it, and would be glad to crate everything up, and load it on a truck if you arrange shipping.
