4x4 conversion on 93f350 CTD CC DRW. D60 NP205
I'm converting My 93 4x2 DRW to 4x4 DRW using a d60 for the front end. A very kind member here has answered to many of My questions with detail and now believe I'm starting to understand how this works. I start this thread to keep posting some progress pictures until I finish this project (I don't have a tc yet I'm shopping for a divorced np205 driver side drop) mean while I welcome any other member who wishes to lay some light on this thread so that others in My position can benefit from it.
Well so far I got a almost complete 95 f350 DRW d60 (turns out this is a 89 DRW KP Dana 60), comes with 4.10 open I believe (I don't know how to tell), this one is ball joint style (the other is kingpin) is has the f350 springs with the rear brackets (front are missing and I need a pair) stabilizing bar, gear box and steering linkage, all the suspension parts for the shocks and the brackets. It is missing the locking hubs (anyone know where I can get a set of cheap ones?) the front leaf spring brackets and maybe something else I just don't know bc the donor was visited by some one else before Me.
Now the 93 DRW does not have the holes already drilled on the frame which doesn't surprise Me since ford did not make them 4x4 from factory except the centurion but I won't get into that. Fact is mine doesn't have them and I will have to drill holes, anyone know of a good technique to do this? What tools do You use to drill the frame?
I will order some rancho shocks, grade 8 bolts at fastenal (if anyone know all the sizes please do tell) and the front hubs, this last I will buy stock ones if they are cheaper since I want the 4x4 to get Me out of a hole with My trailer behind Me not to go wild off road.
Any other comments as to what to do first?
I will post pics of the parts as soon as I remove the snow on top of the axle .
Thank You.
Thank You.
