Custom Turbo
zigzkidz
Butler, PA
ok i havent really done anything in the past 2 days i **** everything back off and back to the drawing board. I keep debating weather to do 1 up pipe or 2. A bubby of mine has some 2.25 inch pipe hes gonna give me but then i have to make two 2.5inch adapters for the manifolds. Also the oil drain and supply are turning out to be harder than i thought. I have a hose that would work for the oil supply of it were to come from where the pressure sender is located but it would hit the exhaust housing. And if i were to get teh oil from the side of the block i would have to go get a line made. And then the oil drain im not sure what im gonna do about that.
Cat_Rebel
Does not compute
Wouldn't you like to know
Oil line cost me about $27, not braided stainless like I wanted but I haven't found a shop around here to do it. I just kept it away from the heat & keep an eye on it, so far so good.
