I replace my IP/Injectors etc and got it all timed correctly on my e250. Now I was working on adjusting my VRV. Originally the previous owner had it turned all the way toward the cab so that it got into 3rd (its a c6) as quickly as possible. He said he did this because he thought it would help with MPG's. I am going to be towing a travel trailer come spring and am adjusting the VRV so that it will hold the lower gear a little longer. So I have 2 questions:
1. Am I thinking correctly about adjusting the VRV to hold a lower gear a little longer for towing? I am thinking it will help get up to speed and keep the engine in it's power band.
2. As far as mileage...while you want to keep the RPM's down I would think that having it shift into 3rd to soon could hurt your mileage. It gets really doggy and causes you to give it more throttle than you would if you had stayed in the previous gear a little longer. Now I know that in the lower gear you will be turning more RPM, but will the extra RPM's use more fuel than the extra throttle in a higher gear?
Thanks
Thanks
