Cummins ZF5 adapter plate
Discussion in '1st Generation Cummins' started by Stevenjf88, May 4, 2017.
  1. Stevenjf88
    Stevenjf88 Registered User
    Oct 26, 2016
    Louisina
    Looking to have an adapter plate made for my Ford ZF5 trans. Looking for the plate thickness that is needed. Ive seen 3/8,1/2, and 1" builds but unable to verify which was for a ZF6 rather then a ZF5. Anyone make there own, or can verify what thickness is needed?
  2. towcat
    towcat Administrator Staff Member
    17,309
    383
    i have a 6bt to dzl ZF5 adapter plate. I will check the thickness tonite when I go into the shop.
  3. Stevenjf88
    Oct 26, 2016
    Louisina
    That would be great! And highly appreciated!
  4. F350camper
    F350camper BOOST!
    1,713
    287
    Jan 11, 2005
    Northern, VA
    Of course you do! :cool:
  5. Stevenjf88
    Oct 26, 2016
    Louisina
    Any chance your in the shop tonight and on the internet at the same time?
  6. towcat
    17,309
    383
    it's possible.
    -c
  7. towcat
    17,309
    383
    the plate I have on this 6bt is 1"
    u2slow likes this.
  8. Stevenjf88
    Oct 26, 2016
    Louisina
    Does is have a crank spacer on it?
  9. towcat
    17,309
    383
    nope.
  10. Stevenjf88
    Oct 26, 2016
    Louisina
    I appreciate your help! But that just adds to my confusion. Ive seen 3/8 adapter plates that required the factory 7.3 IDI crank spacer. Your 1" does not. If anything, it should be opposite due your plate being twice as thick.
  11. The Warden
    The Warden MiB Impersonator Supporting Member
    36
    7,354
    19
    Fog Bless Pacifica (CA)
    Dumb question, but were those plates that required the crank spacer meant for a ZF5 (or other manual transmission) or were they meant for an E4DOA?
    To the best of my knowledge, on factory applications, the crank spacer was only used with the E4DOA and wasn't used with the C6 or any manual transmission...
    fishingrod likes this.
  12. zebrabeefj40
    zebrabeefj40 Full Access Member
    84
    Mar 13, 2010
    Pepperell MA
    I'll add my ZF5 adapter plate. I used this part from Destroked http://www.destroked.com/shop/index.php?route=product/product&path=35&product_id=55 to install my '01 24V into my '92 F250. No crank spacer, stock 24V manual trans flywheel, the clutch is for a single mass flywheel conversion from the 7.3 IDI - bolted right to the Cummins flywheel; the pilot bearing came with the adapter plate. I've driven it 5K miles since I got it "finished" with no issues.
    Nick
  13. u2slow
    u2slow Plan B
    306
    May 8, 2007
    Salt Spring Island, BC
  14. Samickguy15
    Samickguy15 Windsor Collector
    17
    Oct 25, 2011
    Delavan, IL
    Flywheel shape (ring gear location) dictates adapter thickness. A flat backed flywheel would likely be 3/8". The NV4500 flywheel such as NFW7223 works with the 1" adapter similar to the stock adapter plate. That flywheel needs the pilot bored to fit a 17IDx47OD Ford pilot bearing. The Dodge bearing is 3/4"x1-3/4" (19x44.5)
Share This Page
