GoodB0Y
anyone know what years the 12v had the turbo flange at a 90 degree angle to the exhaust flange?...most seem to come out at a 45 or less... and can you flip one around?
Thanxs,
Corey
Thanxs,
Corey
The manifold came off of a core motor I had bought from a machine shop, and the guy said it came out of an F650.
I will tell you too, with this manifold you won't be able to use the hx-35 as is. In that position it will hit the injector lines, and the wastegate actuator will hit the hood.
If your still looking for that manifold I bought one for my conversion from fordcummins cost was I think 300 to my door (s&h included) new. I talked to Ryan there very helpful. I "aimed" mine down so the exhaust would be easier to run and to keep the heat away from the a/c heat box. Hope this helps.
