Cruise control year fitment
f350CONVERSION
Eureka Ca
I have a 1993 f350 4x4 crewcab 7.3 idi with turbo and the only option it does not have is a tilt column with cruise and the only trucks I can find locally are 94-97 powerstoke trucks I know the column will interchange but I was wanting to find out if the cruise electronics under the hood and dash will interchange? Thanks
jaluhn83
Upper Marlboro, MD
You sure? Just from randomly looking at junkyard trucks it looks like gas & diesel 93+ (i think) seemed to share the same servo unit, which at least on the 93 unit I have has the computer built in. I know the engine is completely different, but cruise system seems to be a standalone system that takes input from the speedometer electronics.
ironworker40
NYC Ironworker
nj
Go to a ford dealer and ask them to give you other vehicles that you can get it from. I did it and had a printout that I can't find but it had pickups bronco's and vans up to around 97 IIRC also different part numbers. If you find them at a reasonable cost I'll buy one from you as I could not find one and I don't want to buy a new one because I'm not 100 percent sure that is my problem.
madpogue
Madison, WI USA
There is no servo on the PSD. There's nothing on a PSD that a servo could mechanically control. The accelerator pedal is just a big "volume control", a variable resistor. AKA pedal position sensor. It's not a "throttle" position sensor, it is, in effect, THE throttle. So the cruise control doesn't have to be any separate physical device the way it would on a gasser with a throttle, or an IDI with a mechanical IP. So when you set a speed on the cruise control, the PCM just tells the IDM and the injectors "give me enough power to maintain X speed".
madpogue
Madison, WI USA
Depends on what it "pulls", I suppose, how it's connected to the throttle. They shoulda designed it like some cars, where the module/servo are inside, and operate on the cable from the pedal under the dash. That would make for a more universal application.
PSD is an odd duck.....
pwillis
