Cruise control quit
chris142
SoCal
Worked yesterday. Pushed the buttons today and nothing. Where do i start?
MTKirk
Billings, MT
Check the switches on the clutch & brake pedals, I have the exact same truck as you and this is the only place I've ever had trouble.
chris142
SoCal
I may be in luck! I pulled the knee panel down to ck the fuses and a little blue one fell out.found an empty spot and pushed it back in.i also noticed that theres nothing holding my fuse box in.every corner thats supposed to hold a screw is broken.so it just bounces around i guess. We will go out in an hr or so and ill try the cruise then
gandalf
Senior Member
CA &/or Maine
How does your horn work? My '86 had the cruise go out, and the horn at the same time. On my '86 there was a relay which powered both the cruise and the horn. Strange combination. I found the relay up under the dash, about mid-way across.
Will your '87 be the same? Not really sure, but it's worth a test/look.
chris142
SoCal
Horn works. I have no idea how to diagnose this system.i know that the thing with a cable coming out of it uses vacuum to pull the throttle.other than that im lost
chris142
SoCal
All fuses are good.Theres a switch on the brake pedal that has a vacuum hose going to it.where can i buy the switches on the steering wheel?
gandalf
Senior Member
CA &/or Maine
The Tech Articles has a write-up on diagnosing the electronic cruise control. I think, though, that your's is vacuum, isn't it?
I have a diagnostic for the vacuum cruise setup. I'd paste it in here, but it's 30 Kb, perhaps a bit big. If you'd like a copy I'd be happy to send it as an email attachment. If so, PM me with your email address, and I'll get it off to you.
chris142
SoCal
Ya mines vacuum operated. Im going to guess i have an electric problem.the brakes and dash work fine
chris142
SoCal
Are their any other fuses in my truck besides the ones by my knees?
chris142
SoCal
I cant find the how to for the cruise. Can soneone post it? My world is upside down without cruise
Poway, CA
This is going to sound dumb, but check the cruise cable. The cruise on my truck stopped working once. Turns out the cable had popped out of the holder on the injection pump.
Mike
quicklaptoprepair
Staff online
