Cracked Flexplate
Discussion in 'Lounge' started by FordGuy100, Aug 8, 2017.
  1. FordGuy100
    FordGuy100 Registered User
    26
    8,360
    48
    Apr 1, 2006
    Silverton, OR
    Listen and let me know what you think
    This is very quiet but sometimes it sounds like there is a rock or bolt loose in there. Driving around, 4th gear has a very pronounced transmission noise which I can best describe as what an engine fan hitting something, would sound like.
    05 burb 2500 6.0/4l80e
  2. 79jasper
    79jasper Chickenhawk
    24
    13,288
    218
    Oct 13, 2012
    I don't know how common cracked flexplates are with these.
    But I do know a failing torque converter can do that.
  3. OLDBULL8
    OLDBULL8 Good Morning Ya'll. Supporting Member
    88
    9,738
    146
    I had almost the same sound on my 99. The TC bolt/nuts came loose, eventually one bolt tore loose and lost all the oil.
    Pull the dust cover and check the nuts/bolts.
    icanfixall likes this.
  4. FordGuy100
    26
    8,360
    48
    Apr 1, 2006
    Silverton, OR
    I did pull the cover and looked it over and from the angles I could see (dust cover sitting an inch below held in place by trans cooler lines/tight fit) nothing appeared out of place. But I've read that they generally crack around where they bolt onto the crank and its hard to see from underneath.
    I think I'm going to pull it and throw a better flex plate and a tighter converter in it. Sometimes its much much louder then others, this was relatively quiet.
  5. FordGuy100
    26
    8,360
    48
    Apr 1, 2006
    Silverton, OR
    Went ahead and ordered a TCI SFI rated flex plate, and a Hughes "Fuel Miser" torque converter (stall 1000-1200 rpm's) since most of the driving this thing will see is in town <50 mph.
    Oh and getting a 89 octane tune from black bear tuning.
  6. FordGuy100
    26
    8,360
    48
    Apr 1, 2006
    Silverton, OR
    More then just flex plate
Share This Page
