Cowl air intake.
thx997303
utah
I built an intake similar to the hypermax intake today. Man, what a difference. Better throttle response, feels like more power.
But man, cutting the hole for it was a pain. I cut a 4" hole to the passenger side of the brake booster with a hole saw. Darn spot is not flat.
Anyway, used a dryer vent tube and a 90* elbow. Works great.
This should be done to all of these trucks in my opinion.
thx997303
utah
Well here's the hole in the firewall.
And here's the coupler I used placed in the hole.
I'll post a pic of the completed thing when I take one.
thx997303
utah
And here it is, in all it's ugly splendor.
I think I'll replace the aluminum pipe with plastic, but I had this lying around. I also intend to seal up the whole thing with HVAC aluminum tape. Should work nicely.
Also, I gotta figure out why my pictures always come out blurry. Hopefully I have that fixed.
kc0stp
30 Hour Famine
Colorado
Cold (outside) + pressurized air vs hot (engine bay) + static air
Air pressure builds up off the windshield so its forced into the intake. This is an old drag racer and NASCAR trick from many years ago. EVERY NASCAR intake is designed this way. Watch for it next time you watch a race or see the hood off a car in the pits.
johnkracing
chilliwack bc
Still has that nice cast aluminum air preheater like mine, workin on a setup to get rid of that on mine then may resort to pulling factory turbo since I was unable to remove 2 of the outlet bolts to go 3in flange to dp.
thx997303
utah
heartfire567
