jimcaf12
Trying to sort thru and get my gauges working after an engine conversion , I believe its a red with a white strip?,im not getting movement at the gauge when I connect it to the stock sender, im reading 12volts there at the wire coming from the gauge
with my multi meter so I didn't want to ground it and burn a fuse or worse smoke the gauge..
Thanks much any responses
