themechanicalford
In cold weather I was curious as to the safest way to extend idle the truck once it's hot? I've seen some things on here about switches you can use to control certain aspects of the timing and throttle speed.
If I am out and want to idle the truck for an hour or more for cab heat should I try to use the pedal to vary the RPM's, should I just let it be, should I add some sort of manual override?
Also would regular 15w40 be my best bet in these circumstances? I've heard people talk about switching to a thinner oil in cold temps. We live on top a mountain and deal with temps down to the single digits regularly.
Thanks!
Thanks!
