Tis the season for these threads. =P
You don't need to cycle the pedal to activate the cold timing advance, that happens automatically. To test it, you can start it, and then unplug it. If your timing is correct, you will hear a distinct rattle to how it runs while the cold advance is energized. It will smooth out to its normal sound when you unplug the advance, then start rattling again when you plug it back in. Even if your timing is retarded, you should still here a difference in how it sounds.
The cold idle however, you will need to cycle the pedal to activate. The plunger simply isn't strong enough to move the throttle by itself. To test, turn your key on when the engine is dead cold, then cycle the throttle with your finger, you should see the plunger pop up.
To test just the sensors for both of these, just disconnect them, and plug a test light into the connector. (key on, engine cold) if it lights up, the sensor, and wiring, is working. While you're at it, go ahead and test all your glowplugs too. (clip the lead of the testlight to B+, and touch the top of each of your glowplugs. No light, no worky. Replace any bad with Motorcraft glowplugs ONLY! or you can kill your engine)
If it starts giving you more trouble starting in the cold, you can always try plugging the block heater in an hour or two before you need to leave. That should make a huge difference in how she starts.
