Clutch Questions
Ross01
Beggs, OK
Okay, so I finally found all of the parts I need to convert my truck to a ZF5. Only problem is, the parts are from a 92 and the truck I have is a 91. I've been told that the pedal assembly is different, and that the slave and master cylinders are different between the 87-91's and the 92 and up. Anybody know?:dunno
biggin92
Yeeeee Haaawwww
umatilla fl
yes the pedal assembly is different and so is the master cylinder but the slave and the line are the same.;Sweet
hesutton
The Anti-Anderson
Bowling Green, KY
I've never seen the pedal assembly out of a '92 and up. The old assembly from the '83-'86 IDI's is certainly different that the ones used in the bricknose era ('87-'91). I was under the impression that the assemblies from '87-'97 and the slave cylinders were all interchangable?:dunno It's simple to find out. Once you remove your peddle assembly, compair the two side by side. If they are the same (except for the clutch pedal of course) great, if not, keep looking.
Heath
