Kingralph88
Op
Put your trucks specs in your sig line so we can see what we're working on...
1985 F250 XLT Lariat 6.9 IDI 4 Speed T-19 OD w/ ATS Turbo
Ok yes I will take a pic as well and post when I am there next, I wish I had a working assembly and could see what it should look like. I’ve never really looked down there when pushing in the clutch when working properly.You most likely wont need a true clutch kit.
It's definitely the pedal assembly .
Look closer at the spot the upper pedals hang from while you are pushing down the clutch pedal.
Bullnose trucks are different from the above pic. Similar but different...
The master cylinder looks pretty rusty & original, I did not check fitment of the fasteners. I did open the lid for filling the slave cylinder & it was full of oil still. The oil around the cap is my doing, I took the black plastic sleeve out and it was sitting in the oil.Are the fasteners tight on the master and the slave cyl?
I took at pic of the slave cylinder when I was under but did not check for fitment (did not know what I was looking at until now). I think it was replaced sometime recent? It looks newish compared to the rest, also not sure how they should look normally (white plastic piece looks funky?)
