Cleaning up the shop
Status
Not open for further replies.
Thewespaul
Bulverde, Texas
customer of mine is cleaning up his shop, he’s got some good parts he wants gone, here’s a list of the highlights:
*parts are located in Galveston Texas, local pickup is preferred but shipping is a possibility for some of these parts.
zf5 4wd trans (disassembled)
1356 transfer case
1345 transfer case
NV4500 2wd (has the brake)
NV4500 4wd tailshaft housing
NV4500 4wd mainshaft
C-6 cast iron t-case adapter
2 Dana 50 ttb axles 3.55 and 4.10 (I know everybody loves these)
NP205 t-case passenger drop rebuilt
NP205 to turbo400 adapter
292 chevy engine complete disassembled
250 chevy longblock
2 SM465 transmissions disassembled
Dana 60 front axle passenger drop
set of 62" rear leafs with custom shackle reversal brackets(I made these)
set of 53" front leafs with custom brackets and shackles(I made these too)
NP205 internal parts, used but look good
Dana 70 dually rear axle
Clark 5 speed from C60
Spicer CM 5252-A 5 speed professionally rebuilt
Chevy and Ford flywheel cover adapters for above trans
Spicer rear axle model 19060S new disc brakes and lines 3.36 ratio
HO72 rear axle
set of 4wd driveshafts for a 93 f250 scab with 8' bed
austin92
Brazil. IN
How much for the dana 50 4.10s to 46171? I’d rather do a 60 swap but the 50 does what I need it to do. Is that 205 divorced?
Thewespaul
Bulverde, Texas
You want the whole axle shipped to Indiana? I don’t think the guy will want to ship that far but I can check for you.
205 is not divorced
austin92
Brazil. IN
No, just the ring and pinion if it’s clean. My 88 has a 3.55 dana 50 and I wanna swap gears
Status
E Moeller
