changed fuel filter now truck wont start.
94250turbo
Detroit
I changed the filter and filled it with diesel kleen. My truck wont start and the tube at the bottom that just pulls off where it turns into a metal line that dosent connect to anything fuel is coming out there while I was trying to start it?? What do I do? All the fuel coming out of that line has me concerned.
texcl
W. of Cavalier, ND
Sounds like he pulled a return line? All the lines should be connected if not then air will get in and not allow starting did you press the valve stem looking thing on the side of the filter assembly while turning her over to purge the air out? BTW lots of fuel runs through the return line, way more than you would think.
94250turbo
Detroit
Yea I had someone crank while I purged the air until fuel was coming out but still wouldn't start. Here are some pictures.
[/URL]
[/URL]
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
remove the filter and see if it is still full. if it isn't, the drain isn't closed. I never touch them drains when I change mine. never even hook the little hose back up.
94250turbo
Detroit
I did that and the filter was still full. I noticed when I took the bottom filter housing off (I used a screw driver and hammer with a few taps) a bolt head was broke off in the filter. It looked like it goes to the drain valve on the inside part of the filter. That couldn't cause my problem could it? Everytime I crank it over fuel poors out of that line.
gandalf
Senior Member
Air Force
CA &/or Maine
So have it a little loose? I have the drain valve tightened up right now.
No. He's saying turn it all the way in the other direction. Tighten it down the other way.
You can't be sure how that valve is built, how it closes and how it opens. On top of that, it's upside down. I have to stop and think every time I mess with it.
Your talking about the filter water drain valve with the line that goes to nowhere. That usually never gets messed with. Please remove the bottom of the filter and look closely at what in the bottom cover cap. One in the center is the drain and the other is the water in fuel senser. Its what you have to work with. Can't tell you why something was broken inside the bottom cap either. Sometimes the drain valve gets sand crap stuck in the seat and it wont seal up till you open it and clean it out.
94250turbo
Detroit
I pulled the filter back off and actually it was not full. Would this broken piece here cause it do drain all the fuel I put in the filter out? Now that I think back to when I put the bottom of the filter on it was leaking out of the black tube that the drain line connects to but I didn't think anything of it. Im wondering if this broken piece caused the filter to drain out which in turn caused my truck to not start. then when I messed with drain valve on the outside of the bottom filter housing it broke. So now the whole drain valve assembley is toast.
[/URL]
theguruat12
Certified Tinkerer
Albuquerque, New Mexico
That looks shot to me, it looks like the broken-off part holds the valve closed when screwed all the way in. Either buy a new bowl bottom (expensive unless you find one at a junkyard) or run a WIX 33617 like this: http://www.amazon.com/Wix-33617-Spin-On-Separator-Filter/dp/B000CSEVHI
It has an integral bowl and drain, and even has the port for the water-in-fuel light. I run the 33417 which doesn't have the sensor port, since mine isn't hooked up right now. No separate bowl means one less seal to leak.
If you want to go the original way and replace the bowl, I have one off of the filter head I got at the junkyard. PM me about it if you're interested.
94250turbo
Detroit
So the bottom bowl and valve comes as one whole assembly then? There is no just buying the valve and calling it a day?
bneumann22
