ISPKI
Hey guys,
I have a 94 F250 idi. I did a zf5 swap in over winter and when I tried to fire it up after swapping the trans, I cooked some electrical wires, roasted a solenoid, popped some fuses for the GP charging system. I found that the large (10 gauge?) red/green stripe wire that connects from the GP relay power input post all the way through the cab to the ignition switch had continuity to ground.
I traced the wire through it's plugs until I got into the cab and determined that it was grounding out somewhere up above the pedal assembly inside the dash...somewhere, I couldn't access the 2 ft of wire where it seemed to be grounding. I cut the wire after it entered the cab and just before the ignition switch and ran a new wire outside of the pedal assy so that I could start the truck. Problem now is, my alternator is not charging and none of my gauges work except the speedo.
