C6 3-->2 downshift mph?
turboman1
Tucson AZ
Truck doesn't downshift from 3-->2 until I get to about 15 mph (which is about where it shifts from 1-->2 on up shifts). Tranny started doing this after it was rebuilt, but before it did it at about 25 mph. Is this a valvebody adjustment that can be done, or is that the normal downshift speed?
1984 F250 6.9, Stock size tires and 3.54 gears.
Thanks
Adam
You can mess with the VRV valve on the throttle linkage at the injection pump, or you can pull the hose off the vacuum modulator at the pass side rear of the tranny and stick a small screwdriver up in the nipple for the hose and turn the adjustment there. Just make note of where you started in case you go the wrong way.
They might have put a new/different modulator on it. They have colored bands on them, they come in different versions. You should be able to adjust it and bring it in where you want it though.
bneumann22
