Burning Off Rotella Really Fast..?
cubinzkid
American Fork UT
CDR? Whats this? By oil coming from the valve covers, I meant I pulled the driver side valve cover cap, and at idle, there was a steady roll of "steam" that was oil. Just a lot of blowby, and while I have a tired engine, I didn't know if Rotella was adding to this effect.
BrandonMag
Dana 50 rebuilder
Oregon east
I run Motorcraft usually.
A couple years back, I decided to run a treatment of auto-rx and man what a difference.
I did the same thing shortly after I bought my truck (five years ago). AutoRX is awesome. Highly recommend.
Hydro-idi
Lodi, California
Yes, I plan on doing a second treatment in the near future. When I recently did HG's, I couldn't believe how clean everything was inside my engine. Now....I didn't see what it looked like before auto-rx treatment, but I bet you it cleaned things up in there. I am not here to promote products or push them on anyone. Just giving some insight on what has worked for me.
freebird01
Post Turtle!
Fort Wayne, IN
when i first got an idi i used rotella and it went though it like others are descrbing. since ive been running chevron delo or mobil delvac with good results
C_Luft
Vancouver, WA
Cdr, its like a pcv valve for the older idi diesels, it separates the oil from the vapor and drains back down into the valve cover and it prevents a runaway situation. If your cdr is still painted it's probably original, and should be replaced.
chris142
SoCal
I put MAG1 5w40 in mine for winter. It's really drinking it! A qt in 200 or so miles!
idiabuse
Princeton Fl
Mine leaks like normal, right? a few drips here and there like $38 a gallon like every 6 months and 12,000 miles, if it didn't leak would it use any? what a pain
pwillis
