bunching speedometer
Ole BlackBetty
Norman, Oklahoma
ok I read a few threads, but did not give me answers.
At 60mph and above my speedometer needle bounces violently. I do have a flashing od light. trans pulls and drives good tach is steady. I clear the od light everyonce in awhile and after driving up to temp. it will come back on. Trans temp runs about 155 on interstate at 65mph.
Clb
Another old truck
nannyfornia
Yes
And
Details
Tranny needs p.m.
Speedo electric or cable?
94 should be electric I think on slushbox so speed sensor or gauge...
u2slow
bilge rat
Coastal BC
If it's electric signal, check rear the diff. The tone ring could be damaged, loose, or metal debris is rolling around in there. (Seen it happen before.)
  • Like
Reactions: Clb
Ole BlackBetty
Norman, Oklahoma
Yes
And
Details
Tranny needs p.m.
im thinking tranny needs a new convertor at the least. as far as elec. or cable IDK. i know it drives fine, runs fine but needle is dancing past 60
My 86 bounces around also, and it is Cable driven.
Even with my new OEM Spedo 6 digit head, it bounces around.
It has to be the old cable doing it. The cable runs off the T-19 in
my case, and thinking I need a new one, most likely the original.
And being 39 yrs old and 365K miles, cable probably rotated a few
times inside the sheath.
Clb
Another old truck
nannyfornia
lube from top down????
