That's just me guessing. I very well may be wrong.Well, I guess it's time for a P/N look up!
It won't happen tonight ... but I 'll have time in the morning.
Obs is the exception, but short wide rads DO use the same core support as the gassers
Unless you try to go by LMC Truck. They only list a gas one for Bull Noses (of course since they no longer make new ones). For the Brick Noses, they list one for gas and a taller one for "diesel without air conditioning". That made NO sense since they didn't list the diesel with A/C option. For the OBS, they list gas, IDI diesel, and PSD diesel (by dates made, not by type of engine). That didn't make sense to me either because I thought that at least the OBS 7.3 PSD used the same radiators as the 7.3 IDI did. If so, why would they need a different radiator support? Especially with a mid year switch between the IDI and the PSD.Obs is the exception, but short wide rads DO use the same core support as the gassers.
doesn't the lower rear of the fender mount completely different also? 80-86 bolt mounts upward and 87-91 points straight in. can be modified, but not a bolt on....................doesn't the lower rear of the fender mount completely different also? 80-86 bolt mounts upward and 87-91 points straight in. can be modified, but not a bolt on....................
