Okay. 7.3 idi turbo and the blue bullet connectors keep sliding off. Any high speed, Rooty Kazokie, Super Dooper, better connectors other than the blue bullets? Or just squish them down and force them on?
I used 3.5mm or 4mm silicone vacuum hose to hold the bullet connector on the glowplugs. The 3.5mm will hold tighter but the 4mm will be easier to work with.
