Runningaford
I don't think it's built, just resealed....... the turbo set up looks homemade, and figured you guys would find it interesting..... Would this even work very well?
http://seattle.craigslist.org/see/pts/5462038083.html $2,300
"I have here a 94 Ford 7.3 idi with a Banks Sidewinder turbo kit, This is a factory turbo engine that has 28k miles on it. The engine was torn down to the block and inspected, all the gaskets and seals were then replaced and the engine was reassembled and painted, then a new injection pump and injectors along with hot start glow plugs and a smart controller supplied by industrial injection were installed. then to finish off the exhaust I installed a fresh rebuilt turbo along with ceramic sprayed manifolds, turbo hot side and down pipe. It is ready to install with new fuel and oil filters and fresh oil. Comes with 140 amp alternator and newer starter. Was bolted to a five speed and had a broken dual mass flywheel so does not have a flywheel. Comes with full exhaust front to rear for a standard cab long bed. Turn key engine. asking 2,300 have receipts for everything."
Can anybody help me conceptualize this?
