ken74amx
Cool build! I put an idi in my 79 bronco years ago. I no longer have the truck though. Illinois state police took it from me for too many overheight tickets! By the way I'm in Mchenry. Bout 25 minutes west of you.
I'm running the stock fan w/a custom shroud.
It's tight, I can't remove the fan without taking the shroud off at the same time.
I'm going to switch to electric when I pull the motor for the cam swap and studs.
Dennis
Are you running a stock alternator?
From a company that rebuilds starters, alternators, and other vehicle electrics in all forms from standard to extreme duty - I was told that a stock alternator would handle most vehicles even with a bit of upgrading. But I live by the motto that over building everything is still not heavy enough. But I guess the single wire alternators aren't truly the best for us diesel owners since it requires a bit of RPM to start the charging process.
I was working on my current project which is putting a 6.9 into a gas project and I was wondering what the motor mounts look like on your 79 and which engine came stock in it. Was it a modified?
Hi I have to ask, how hard was it to get the 6.9 and radiator into the 77 chassis (I am assuming it has the narrow frame and funky steering)? Like motor mounts? Maybe PM if you think this is a hijack.
Sorry dirtbiker, I just wanted to have as much info on your swap by others' information as well. It helps me visualize the swap better. Plus I was trying to figure out how you worked in the clutch setup. Is it hydraulic or somehow just hooked up like the older standards were...
This is so cool!
I love that someone is doing the swap as well as sharing information requested. This looks like it's going to be one hell of a truck too!
