Well, it didn't get finished tonight so guess who gets to finish their truck in a snow bank tomorrow. ME! YAY!
I would have had it done but yet again the incompetence of others has set me back almost half a day. Autometer will be getting a phone call and someone wont be able to sit down when I'm done with them. Out of the three new gauges I purchased, pyro, boost and oil temp, the pyro was missing about half the items it was supposed to come with for mounting options of the probe including the weld in bung that I normally use to put it in the crossover pipe. The oil temp gauge required the ordering of a special bung, a part # is given when you order the gauge. I didn't discover until this afternoon that the bung I had welded into the oil pan was not pipe thread, but was a specific thread given to Oxygen sensors and the only means of making the thing work was to drill and tap the thread protector plug for the sensor and seal it with a nylon gasket like a drain plug. I made my own pyro bung from some bar stock and drilled and tapped it as well.
It's just ridiculous that a person cannot depend on a company as well established as Autometer to get you the correct or complete parts that you order.
So anyway here are some pics from todays progress.
The turbo is on and its feed lines are hooked up. Lots of stuff done that you just cant see.
