Brick nose steering column for cab removal
laserjock
Almost there...
Hey guys, noob question (feels like it anyway). Opinions on where to break the column apart so I can pull the cab? I've about got everything else apart, I think....
Thanks!
Sent from my iPhone using Tapatalk - now Free
junk
Paullina, IA
On the steering shaft from teh column to the steering box is a u-joint. The end pointing to the column has a bolt in it. I normally break them apart there. Pull the bolt then slip the column out. You can also pull the bolt at the steering box and pull the steering intermediate shaft there, but that seems to come apart harder.
Whoa...are you wanting to leave the column in the cab and remove the cab from truck?
Just unbolt the steering shaft from column to steering box in engine compartment...really simple...
If you want to remove the column you still have to remove that shaft however there is other things to deal with...auto or manual colum???? need more info to answer!
laserjock
Almost there...
It's manual.
I saw the slip joint in the intermediate shaft (guess that's what is call the one between the universal and slip joint). Pulled the bolt but I can't for the life of me get the coupler off the shaft coming from the cab. Is there something besides the bolt and the ubiquitous rust holding it on?
Sounds like the collapsible shaft is rusted in place...can you take and remove the bolt on the steering box too then when you remove the cab the shaft should be easy enough to slip off...you should consider getting it apart and repaired or replaced as it should slip freely...I have a rusted one too and it's a PITA to deal with...
Moving freely it allows some wiggle room when cab moves on mounts, and when solid it strains the column more than it should be...
You can remove the five bolts holding the big keyhole plate to inside cab and then the two bolts holding column to dash mount/support, then you can slide column out a bit drop it and disconnect the large wire connector. That's about it.
JM2CW
laserjock
Almost there...
Thanks Al. Good idea. Ill take a look at it in the morning. I'm beat tonight. Just went and read up on the slave cylinder via one of your tech 101 threads. ;sweet
waltynguyen
Staff online
