1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Brake grease
Discussion in 'Lounge' started by chillman88, Oct 9, 2019.
  1. chillman88
    chillman88 Supporting Member Supporting Member
    3,642
    2,692
    Feb 22, 2017
    Central NY
    I've seen LOTS of brake failures from people using Anti-Seize on the adjusters and the slide pins. It just dries and kinda turns into a thick putty and binds everything up. I had been using the green goop that Permatex sells but it's just too thick to work properly. I did a little looking around and found lots of people using silicone paste. It got me thinking...
    What does everyone on here use to grease up caliper slides and drum adjusters?
  2. 79jasper
    79jasper Chickenhawk
    27
    16,962
    1,706
    Oct 13, 2012
    I think mine is the synthetic permatex stuff.
  3. lotzagoodstuff
    lotzagoodstuff Supporting Member Supporting Member
    2,238
    209
    May 19, 2007
    Maple Valley, WA
    I like Lubriplate or Lucas Red & Tacky.
    Oledirtypearl86 likes this.
  4. Oledirtypearl86
    Oledirtypearl86 Full Access Member
    34
    1,309
    669
    Sep 17, 2018
    Whitehall MT
    Red tacky or dielectric grease have been for years
  5. Ironman03R
    Ironman03R Full Access Member
    37
    2,181
    116
    Jan 8, 2006
    Risingsun, OH (NW OH)
    I used to use anitsieze, but now use the green silicone brake lube.
  6. chillman88
    3,642
    2,692
    Feb 22, 2017
    Central NY
    Thanks guys. I was just curious. I'm glad to hear that you aren't all just using anti seize haha. I'm also glad to hear that some of you are using silicone/dielectric or similar. That's what was recommended from what I had read and seems to be the ticket from the few times I've used it.
    This is what I've started using:
    https://www.amazon.com/dp/B005RNEH5O/ref=cm_sw_r_cp_awdb_t1_76OODbK6DASF3
  7. riphip
    riphip Supporting Member Supporting Member
    733
    208
    Nov 16, 2005
    Memphis, TN.
    Is same as I use for a bunch of stuff. Great on batteries & cables too!
    chillman88 likes this.
  8. typ4
    typ4 Supporting Member Supporting Member
    59
    8,729
    842
    Dec 24, 2005
    Newberg,OR
    I thin down the copper never seize and use it, seems to hold up well.
  9. Ironman03R
    37
    2,181
    116
    Jan 8, 2006
    I agree the copper anitsieze is way better
  10. chillman88
    3,642
    2,692
    Feb 22, 2017
    Central NY
    The copper never seize seems way more... Liquidy? I can see why it might last longer without drying out.
  11. jwalterus
    jwalterus Made in America
    2,535
    707
    Feb 11, 2010
    Minot, ND
    Loctite C5A spray for me
    Jason1377 likes this.
  12. typ4
    59
    8,729
    842
    Dec 24, 2005
    Newberg,OR
    I imagine new copper never seize is more liquid, when we did the papermill demo there was hundreds of cans of dried out copper sitting around so I reconstituted it with Marvel's mystery oil, works great.
    Jason1377 and chillman88 like this.
  13. Oledirtypearl86
    34
    1,309
    669
    Sep 17, 2018
    Whitehall MT
    I have a guy that brings his truck in to me and his last mechanic used copper anti seize on everything. M y only complaint is it's worse than glitter all you have to do is look at it and it's all over everything and makes my nose itch
    saburai and chillman88 like this.
  14. chillman88
    3,642
    2,692
    Feb 22, 2017
    Central NY
    Oledirtypearl86 and saburai like this.
  15. saburai
    saburai Supporting Member Supporting Member
    2,025
    852
    Mar 15, 2016
Share This Page
