Boost 15lbs & 2800rpm & 900 Degrees.....
Well after switching the injection pumps and really not knowing if I'm running the Moose pump or the Pensacola pump I towed my metal 3 horse trailer with one **** on board. Saw these numbers and probably could have seen a couple of lbs more boost but had to let off the skinny peddle. Not sure of the mileage yet but think it was 110 miles on maybe 7 or 8 gallons.. Will know for sure when I fill the tank. I was more than half tank on the front tank and I know thats a 19 gallon tank. It was less than 5/8 full but more than 1/2 full too. We will see. Truck actuall saw 210 degrees too... Wow I never see temps in the 200 range.. Lucky me.. My engine oil temp reached 250 pulling the long grade that was less than 6%. I just dropped it out of od and not in gear vendors od either. Just 3rd direct and I was speeding up with ease.. Nice day too...
My oil temp sender is located about 2 inches above the bottom of the oil pan on the drivers side. I actually made a bumg and tig welded it in when I rebuilt my engine.
FORDF250HDXLT
Maine & Oklahoma
oh man that's nice! just want id like to do.if i don't remove the pan,i guess i can just tap it?
Not really possible to just tap the pan for an oil temp sender. It surely will leak. Now if you try to do that I would sure make sure I used some rtv around the finished sender to pan joint. Even then I expect it to leak.
FORDF250HDXLT
Maine & Oklahoma
yeah dang.i guess i got to just get busy and pull it before cold weather and be done with it.
waltynguyen
