blown gasket or worse
jhowse
alabama
I was replacing a valve cover gasket today and found lots of moisture in valve cover and light grey oil, also the push rods are rusted. Is there any way to tell if this is a blown head gasket or worse?
dyoung14
Is getting worn out
spencer,tn
6.9 are bad for head gaskets letting loose, its a good possibility that thats what happend, also the oilcooler o-rings could have went causeing the same problem
jhowse
alabama
thanks for the input going to dig into it tomarrow, have any idea what the torque specs on these heads are.
dyoung14
Is getting worn out
spencer,tn
my servic manual says to torqure in 4 steps
1st......40
2nd.....70
3rd.....80
4th.....80
and intake manifold torques to 24 ftlbs
87crewdually
Southern Nj.
I had the same prob and here is what I had:
That's worse case scenario. It could also be the intake manifold pan/gasket. The pan gasket blocks water ports that if leak puts it right in the valley. I think this is more of your problem. You would remove the intake any way to do the head gaskets.
Here's the other stuff. You should be able to torque them to 85ftlbs.
The other thing you want to look into is the oil cooler on the driver side of the engine as seen here with the red ends.
The orings get from ford or International. 2 o-rings on both ends of the tube, and they are both different. Gaskets you can get from auto parts store. Use thread sealent on the bolts and dry on the gaskets with the built in silicone bead.
PART #'s
It uses a total of 4 orings, 2 outers and 2 inners.
International part #s are for a bag of 2 rings
-thicker ring 1804414C1
-thinner ring 1807563C1
Here's the #'s at Ford call them too
Oil cooler O rings - Ford - 1C3Z-6K649-BA
Oil cooler O rings - Ford - 1C3Z-6C610-BA
Oil cooler gasket - Ford - E3TZ-6A636-G
Oil cooler gasket - Ford - E3TZ-6A636-H
jhowse
alabama
just an idea, how hard are these motor to pull i was thinking i need to put a new clutch in sure would be easier to work on the motor out of the truck. will the motor pull out the top of the engine compartment. thanks
87crewdually
Southern Nj.
Sure will. Remove everything off the motor as seen in my above pic (crank pulley will "touch" radiator if left on) and it will come right out the top. That pic is right before I put it in my truck.
These things dressed are heavy so I used a fork lift, but a heavy duty engine hoist will work fine.
dyoung14
Is getting worn out
spencer,tn
personally i think pulling the motor will make changing head gaskets easier, i mean you can do it with the motor in the truck but if you want to change clutch to you might as well pull it, and to make it the easiest then you should pull the radiator and core support that way you dont have to lift the engine very high
dyoung14
Is getting worn out
spencer,tn
i remeber you saying you had headgasket troubles lately, and you got studs, did you pull the engine to change it with studs or did you manage to do it with out pulling it?
87crewdually
Southern Nj.
I redid both sides WITHOUT pulling the engine. 2.5 hrs the passenger side was off. Going back together took longer because of the dam banks tranny dipstick tube.....long story.:backoff
Now that I remove the ac box cover it's really not bad at all. I think now the driver side is harder. I don't like telling people to remove the front core because on these trucks it opens a whole can of worms. Between rusty stubborn body mount bolts and discharging all your A/C refridgerant it isn't worth it at all to me to go that route, not for as easy as it comes out the top with plenty of room.
Here's a pic with the A/C box cover out of the way:
Plenty of room for the torque wrench:
