Bellhousing question
kbenz
kannapolis, NC
what t18 bellhousings fit the 7.3? is it just the 6.9 and 460 or all big block t18's? got a little project i'm thinking on once I get my oil consumption issue straightened out.
Thanks
u2slow
bilge rat
Coastal BC
6.9/7.3 are on their own. 460/400/351M fit each other.
They do look similar though.
ttman4
Last Nite's Dream..
The others would work if modified/drilled.
The diesel ones are hard to find around here
Yeah as I understand, the diesel and the gas are Bell housing or different and something has to be drilled and modified.
If I recall correctly, four of our diesel bolts fit, then two more has to be re-modified
Friend of mine has a five speed ZF guesser tranny. He is debating about maybe giving to me.
If he does, I’m going to put it in Bessie.
If I do it, I’m going to have to get back on here and find out for sure what bolt holes need to be modified and how to do it for sure.
(maybe I’ll just get some gorilla glue and glue them together what you guys think about that?) lol lol
ttman4
Last Nite's Dream..
Me and Siri still cannot get along! I’ve had her for seven or eight years, and she still cannot understand my talking and lingo!
That last post I did I had to go back and edit and edit and edit and edit it!
Sighhhhhh…..
Smitty 90idi
Army
California
Add some duck tape as well just for good measure. It helps with vibration.
lotzagoodstuff
Carmel, IN
Pretty sure you are asking if a T18 gasser can be modified like the 460 ZF5 bellhousing, as described below. Again, all the information below is pertaining to the 460 ZF5 bellhousing, which can definitely be modded for IDI use. If you find out the answer is no on the T18, try using https://www.car-part.com/ as I'm always impressed by how much harder to find stuff is within a couple hours of me.
The final answer is, 4 holes and 2 dowels are different, the top ones will work.
I bolted a 460 to my diesel zf. After drilling.
blue original idi holes
pink idi dowels
green 460 bolts
brown 460 dowels
red 460 starter.
oh and someone needs to move this to the tech section if it is worthy.
Attachments​
  • You must be registered for see images attach
Olds64
Edmond, OK
I've read that a gas ZF5 can be modified to fit our IDIs.
Will that Muncie SM420 transmission fit your 7.3? :dunno
kbenz
kannapolis, NC
You think it'll hold up?
Didn't GM update to the SM465 to deal with all the extra torque from the 327 and 350?
They are both built pretty heavy duty. 465 is quieter and shifts smoother. the 420 is already there and hooked to a working pto
u2slow
bilge rat
Coastal BC
SM420 was as heavy duty as it needed to be in its day.... L6's and 283s.
I drove both trans for the better part of 10yrs, plus a few clutch jobs and trans re-seals. They use a 1-1/8" input... where I believe ford used 1-1/16" or 1-1/4". Maybe there's an aftermarket adapter to bolt a GM trans to the ford bell pattern.
I understand the PTO dependency, but have had good luck finding transmissions with a ptos still on them (as opposed to sourcing a specific used one after the fact).
Have you looked for a ZF5 with a parking brake? (88-97 F-superduty). I have a ZF5 PTO I could probably pull a number off to help the search...
jwalterus
Made in America
Air Force
Garrison, ND
Well......
I just dug through some old information on my work computer, I hope this helps someone at some point!
The 6.9/7.3 block is the IH "MV" bolt pattern (same pattern as "T" and "SV" series engines)
There were multiple bellhousing adapters that bolted onto the block, the ones for Ford and Navistar, and then SAE2 and SAE3
Different starter depending on the bellhousing you use though!
I could POSSIBLY track down part numbers for someone if I get hold of Case Reman, but they're all listed as "Vintage" in eParts.......
bneumann22
