I can tell you that the ones between my 7.3 and my zf-5 were exactly 0.5 inches in diameter and 1 inch long. I’m betting that yours are 1/2 inch dowels too, but the lengths are probably different depending on the transmission. They should be available on Amazon and elsewhere, but probably not locally. If you’re in a rush you might get away with buying 1/2” cold rolled steel rod at Home Depot and cutting it down. It probably wont be a perfect 0.500” but if it’s oversized you can spin it in a drill chuck against sandpaper or a file to get it closer.
EDIT: I measured the wrong dowel, see later posts!
