Batteries read 12.7 but slow cranks
Kakash70
Butte montana
So I’m having an issue 1990 f350 7.3 na e40d truck after sitting for a couple hours it got a very slow crank like the batteries are dead but batteries are reading 12.6-12.7 batteries bought 7/23 both bought at the same time new regulator and alternator 6 months ago starter 4 months ago glow plug system 8 months ago I got a 0.06A draw but that’s not enough to kill the batteries within even a couple days charged the batteries outside of the truck 1 at a time after a day same issue.
Yes, any voltage readings you take must be made while cranking. This usually requires a helper operating the keyswitch.
u2slow
bilge rat
Coastal BC
BTW, 60mA background draw is on the edge of being a problem.
My FiL had problems with this. GPS, alarm, and satellite radio were stacking up to too much. Had to let one of them go in the name of battery life.
Edit: fulltime powered USB ports are another gotcha.
  • Like
Reactions: Clb
ROCK HARVEY
Dayton OH
My bet is you need new positive and negative battery cables. Remember, if your voltage is dropping on the way to the starter due to bad connections or cables, the amps are going up due to Ohms law. You might even see the connection on the starter glowing red if it’s bad enough. Lots of starters have died this way.
Tizzy
South Carolina
I recently had a similar issue. Truck would crank fine cold. If ran for awhile, then shut off..then crank right after shutdown, would start fine. Let sit for 30 minutes to an hour…and would not crank like it had weak batteries. Thought it was injector pump going out. Turned out starter was weak and heat sink from engine getting up to temp then shutting off for awhile made starter too weak to crank engine. Put a Powermaster starter on, and problem was completely resolved. Starts amazingly fast now. Not saying it’s your solution, but could be a thought.
Kakash70
Butte montana
Well turned out when cranking voltage would drop to around 4-5. load tested both batteries and they have seen the end of their days. figured out the the amperage draw turns out to be the new sound system I put in couple months back. thank yall for the replies was just able to get time to get it all figured out.
Greenie
I tried various repairs trying to solve a slow start and finally bought a DB Electrical starter on Amazon (currently unavailable) in 2017 - the original starter was the problem all along; either the torque or the starter speed slowly changed for the worse over the years - not so much that I could notice it or think that the starter was the issue.
KansasIDI
I hate printers
Wilsey, KS
Another viable option is a Powermaster 9050, if the DB starters aren’t available
drakwest
