Auto to manual hubs
Discussion in 'Lounge' started by BrianX128, Mar 12, 2018.
  1. BrianX128
    BrianX128 Supporting Member Supporting Member
    29
    1,096
    203
    Dec 3, 2015
    Pittsburgh
    On my grandpa's 90 f150 I'm officially done with the old auto hubs. They go into 4 wheel drive fine but they won't come out. Today I was almost late to work because I used 4 wheel drive to get out of the driveway and 1 hub stuck in lock but one came un done and it made an awful grinding noise trying to move.
    https://shop.broncograveyard.com/mo...-From-Auto-to-Warn-Premium/productinfo/32126/
    I assume this is my fix but.. what exactly are the correct steps if anyone has done this before. I've read a few things online and lots of it seem to have conflicting info.
    My hubs have 5 bolts not 3 which seems to mean something as well.
  2. Double-S-Diesel
    Double-S-Diesel parts seller
    43
    2,423
    19
    Mar 8, 2005
    derry pa
    usually with the 5 bolt hube the double nut/ washer is there already. and all you need is the hubs.
    other wise if you have the rounded hex nut holding the wheel bearings you need rermove them and install the double nut/ washer
    at least this is the info I can recall on them
  3. BrianX128
    29
    1,096
    203
    Dec 3, 2015
    Pittsburgh
    See that's what I thought but I've found several videos of people going in further and removing more crap.
    I found this awful video with awful music of what I think the procedure will be for my truck..
    But he removes 1 thing after the hub itself and I can't tell what it is.
  4. towcat
    towcat Administrator Staff Member
    18,034
    1,215
    i pulled apart a D44hd on a 86 f250 and this was what was inside. and yes, it was a drop-in conversion :D
  5. BrianX128
    29
    1,096
    203
    Dec 3, 2015
    Pittsburgh
    I think I got it. The c clip behind the auto hub was the most annoying thing to remove. Broke 3 picks trying to pry under it before I shoved at it with two screw drivers opposite ends and got it to move away just enough to wedge a knife in the middle and pry it that way.
    New hubs are in, they barely and I mean barely had enough room to get the snap ring on the axle shaft. Which I think means I did this right?
    Either way if i got the snap ring on and the giant circular retainer ring on I'm safe for a test drive right? Wheels aren't gonna fly off or anything haha.. the retaining bolts that take the special 4 prong tool got to remain in there just like they were and that's what holds my wheel bearings and whatnot on I believe ..
  6. DaveBen
    DaveBen Supporting Member Supporting Member
    69
    1,226
    192
    Sep 29, 2010
    Ukiah, Ca
    No, Your wheels will not come off. The hub does not keep wheels on the truck.
  7. BrianX128
    29
    1,096
    203
    Dec 3, 2015
    Pittsburgh
    Well it appears I've succeeded. 4 wheel drive works great and disengaged fine as well. 2 wheel drive low range works also with hubs unlocked.
  8. Jason1377
    Jason1377 Supporting Member Supporting Member
    375
    122
    Dec 12, 2017
    Arkansas
    Congratulations on getting your 4x4 working properly n hubs.
    Note to self get a 4x4 idi
    chillman88 likes this.
Share This Page
