AT to MT. Reverse lights what am i doing wrong?
Greg5OH
MI
truk converted to manual. Have to keep mlps sensor hooked up or ot wont crank. i cut thr black and black with pink wires from mlps and hooked it to thr mt reverse switch, no lights. tried hooked a jumper from white/pnk to p/o, no lights. What am i doing wrong?
Yes bulbs good, switch in tranny good.
freebird01
Post Turtle!
Fort Wayne, IN
the last two ive messed with i eliminated that switch too.....just spliced the two red w/ blue stripe wires together... means you can start in gear but that can be handy to have
Greg5OH
MI
Theyres only one red with blue strip wire going to the sensor.
Your reverse lights are purple/orange(power in) and black/pink(power out to lights). Make sure you have power on the purple/orange wire with the key on. If you do, twist this wire together with the black/pink, and the lights should burn all the time. Then you can go from there.
Greg5OH
MI
Frank ill check that out tomorrow, thanks.
Scout ill take a look at your thread tomorrow, thank u as wel.
Greg5OH
MI
Frank, if i disconnect the purple orange wire from the mlps and loop it with black pink, wont the truck only start when the 5spd is in reverse?
Really some great information about wire colors and harness availabilitys. This should be made into a special converstion post sticky.
pwillis
