Are there really 5 brake bleeder valves?
sparky8251
United States
1994 7.3L IDIT
I recently redid the front 3 lines and the master cylinder so I bled the 4 valves at the tires. Recently, I seem to have found a 5th bleeder valve on the "block" that sends brake fluid to the rear.
Does it also need bleeding?
sparky8251
United States
Well... ****. It's a different size valve for me than the rest but whatever. I guess I need to find tools of the right size and do it it all over.
When I bleed the RABS should I rebleed anything again?
Thanks for the answer!
frankenwrench
overkill is under rated!
Weatherford tx
Me either. Just used box end 8 mm. Had a hard time not stripping it. 149.95 later... Had to re bleed the new one
