gunz
Decided to go ahead adn change the antifreeze since i have a long weekend. I can get fleet charge locally. How many gallons does our cooling system hold. I will be mixing it , not buying the predilited stuff. Thanks
8 gallons if you drain the block. Flush it also if changing over to a different coolant. Some coolants are NOT compatable with each other.
