air lock
Didn't get it on right. Try again.
I faintly remember putting it on and sliding it back into place. Been a while though.
bbjordan
Snow Monkey
Ashern Manitoba
^^ What he said. Put the top of the pump on by kind of sliding on from the front of the IP to the back.
catbird7
PA
Finally! I got it, it purrrrrrs now! Also had to replace all of the "O" rings on the pass side injectors. No fuel leaks and it seems to run great, no smoke while idling must have hit the timing pretty close. Engine must be in decent shape as it has 45lbs of oil pressure and starts with only seven glow plugs. Moving forward, I noticed the tach doesn't work so that will be next. Thanks for all of the help!
Kistthesky
AZ
you will still want to get it tiimed correctly, a qoute from one of mel's write-ups:
"In closing, a final comment, with regard to pump timing. A properly timed pump can make the difference between a great truck which the owner loves to drive and wants to keep, and a truck that the owner feels he may have wasted his money on.* In almost all cases, when the injection pump mark is aligned with the mark provided on the pump gear housing (known as being “static timed”), the pump will be retarded several degrees.* The result is a smooth running engine, with very clear exhaust and the owner may find the performance to be satisfactory.* However, until the pump is advanced to 8.5 degrees (factory spec) BTDC using the pulse method, the true performance of the engine will not be realized.* A properly timed engine (which has been dynamically timed with special equipment) will have significantly more pick up, and much better fuel economy that one that is static timed.* It will also smoke a bit more!* Therefore, in order to get the most out of your new fuel system, it is highly recommended that you seek out a qualified shop to perform dynamic timing on your truck.* Use caution!* Many shops “time by ear” and do not have the actual equipment.* I consider myself to do very well timing by ear, but I have found that I can be as much as 2 degrees off.* Factory spec allows for 1 degree of deviation.* Get a shop that has a good and valid timing meter for the job!* You really can’t substitute the functionality of a good quality tool."
catbird7
PA
Yes, Mel set the timing on my other truck (89 F350 SCLB 4X4 7.3 5spd ATS 093 3"DP 4" exhaust 35" BFG & 4.11 gears) and it works great!
Studebaker62
