Austin86250
well air is back in my system yet again kind of a recurring problem with my truck but this time is worse than ever
I put a clear line from the fuel filter housing to injector cap one and found tons of air
after that I put a clear line on the inlet of the mechanical fuel pump to the metal fuel line that goes to the tank and found tons of air there (I have videos if needed)
here's of all things done to my fuel system:
injector o rings, caps, and return lines replaced (four months 2000 miles ago Delphi brand)
replaced mechanical fuel pump (one month 800 miles ago also Delphi brand)
turned my injection pump up 2 flats (used new gasket)
using the process of elimination I'm lead to believe its either the fuel water separator or selector valve
thoughts?
thoughts?
