dcption
(I posted in the wrong section earlier )
Hey all long time lurker here I need some advice from the experienced. My cclb 7.3 factory turbo truck has lost a cylinder so I will be pulling the engine,well I found a 85 van with a 6.9 with only 5000 on a rebuild for a good price. The catch is the man that owned it got sick and died so it has sat for five years I checked all the fluids and everything appears to be clean. My question is if I pull this motor and put into my truck and swap the turbo over what precautions would you take I know I should change the front and rear seals and probably resealed the oil cooler while its out. How far into it would you go. If the 7.3 isn't too bad after I get it pulled apart I may eventually put it back its only got 150k on it the problem is number 8 only showed 150lbs of compression and I found a piece of a wrist pin retainer last oil change.
